Nikita70 wrote:
My best advice on picking up a Rolex for a good price is to haunt the watch sites for sale forums. That is where I bought mine. Just a few days ago a model very similar If not the exact same one as Magnum had came up for sale for $5400. It sold within an hour. Considering the watch is worth twice that minimum tells you how rare a deal like that is. It really is just a matter of checking all the time and to be ready when a deal pops up because there won’t be a lot of time to make up your mind.
Apologies in advance, but there is so much wrong in your post.
Firstly a Pepsi Bezel Insert can be had for less than 100 Euros
Then buying a preowned Rolex can be a minefield as there are so many variables.
So, you bought your watch 20% below „market value“
I am just curious how you determine „market value“
The price and value of a 30 year old Rolex depends on so many variables:
- does the offer include the certificate? (certificate yes or not can mean several hundred $ in price difference!)
- is the dial original or a replacement? (genuine dials can set you back hundreds of $)
- are the hands original or replaced?
- is the bracelet the original one and how is the condition? (good and period-correct bracelets cost several hundred $)
- when was the last service ( a service alone can set you back 1000$)?
- how is the condition of the movement (waterdamage??) (a damaged movement can set you back several THOUSAND $)
- is there any pitting around the main gasket (new case mids costs several THOUSAND $)
- Very important!!! How thick are the lugs and crown guards ("")
- are there deep scratches, gauges etc. in the main case?("")
- are all parts genuine or aftermarket
- and most importantly: Could the watch be stolen and do you trust the seller that he’ll refund you, if the watch turns out to be stolen?
These factors all influence heavily the value, so I am very sceptic when someone claims hat he‘s gotten a certain watch „below value“.
I am not saying that you where lucky - that I can only tell when seeing good pics of your watch - but after years of searching for vintage Rolex watches, I have never closed on a "cheap deal" as the negatives where so glaring that the bargain price was too high.
But a cheap price alone should not be the reason for buying a particular Rolex.
I usually end up paying the higher end of the range after I have made sure that I am getting an example that ticks most of the boxes from above and is really good!
