| View previous topic :: View next topic |
| How Would You Rate This Episode? |
| 10 (Perfect!) |
18% |
[ 15 ] |
| 9.5 (One of the Best) |
25% |
[ 21 ] |
| 9.0 (Excellent) |
25% |
[ 21 ] |
| 8.5 (Very Good) |
19% |
[ 16 ] |
| 8.0 (Pretty Good) |
10% |
[ 9 ] |
| 7.5 (Decent) |
1% |
[ 1 ] |
| 7.0 (Average at Best) |
0% |
[ 0 ] |
| 6.5 (Not So Good) |
0% |
[ 0 ] |
| 6.0 (Pretty Bad) |
0% |
[ 0 ] |
| 5.0 (Just Awful) |
0% |
[ 0 ] |
| Total Votes : 83 |
| Author |
Message |
IslandHopper Master Flub Spotter
Posted: Wed Oct 10, 2007 4:21 am Post subject: |
| N1095A wrote: | | Don't forget in "Did You See The Sunrise?" TC talks of escaping from kids wanting their bubble gum in a "beat up Cobra". |
N,
Your comment about the "Cobra" reminded me that TC is in deed credited with flying a Cobra (AH-1) in Vietnam. In "Thicker Than Blood" (season 1), it is revealed that TC was indebted to Joey (the buddy he tried to smuggle into the Islands) for "pulling him out of a burning Cobra." I believe it was Magnum who mentions the Cobra.
_________________ The answer is obvious, old man. Logic is irrelevant. It's simply Tropical Madness. (J.Q. Higgins)
| Back to top |
Posted: Tue Oct 30, 2007 4:22 pm Post subject: |
Despite our extensive discussion regarding the OH-58 Kiowa featured in the pilot and flown by TC, I forgot to mention the flub associated with this helicopter:
1. The flub occurs after Magnum empties the envelope containing Dan Cook's personal belongings including his "Team Ring." After emptying the envelope, Magnum flashes back to Vietnam. Watch for the third shot of the helicopter (OH-58 Kiowa). In this close-up shot, the helicopter is seen flying across the screen from the right to left. Look at the tail section of the helicoper and you will see that the word "MARINES" is reversed/backwards as it appears the negative was reversed in this shot. All of the other letters and numbers are obviously reversed as well. The "HY" on the vertical stabilizer should be "YH" and so on. This same flub is also visible in Part 2 of the pilot right after you see Magnum, Phillipe and the rest of the Team waiting at the LZ to be picked up by TC. Phillipe tells to Magnum to take the Team to the chopper and says that he'll cover and Magnum says "Don't wait too long." Then you see the helicopter with the reversed images.
2. A flub involving the "Team Ring" actually occurs just before the reverse image flub mentioned above. As Magnum is emptying the envelope onto the table you will see several other items on the table including Dan's dog tags and keys. However, these items are off to the side and as Magnum shakes Dan's ring from the envelope it falls onto the table and comes to rest far away from the other items. The close-up of the "Team Ring", however, shows it right next to, and almost touching the set of keys that weren't there when the ring fell out onto the table.
3. As you look at the close-up of the "Team Ring" you can tell that the right lower bar is not symmetric with the corresponding bar on the left side. It is not as wide and seems flawed. The flub is that a close-up of the same ring is shown in the ending credits, but the imperfection is now on the left side of the ring, not the right as before. The other thing I noticed about the ring in the ending credits is that the wooden table it is resting on is much darker than the table shown in the guest house for the above described scene. Additionally, the ring from the envelope doesn't appear to be the same ring worn by Dan Cook after he was punched in the stomach and is seen grabbing on to the chain-link fence. The imperfection does not seem to appear on the ring worn by Dan in this scene.
4. Magnum's uniform does not include the S.E.A.L. Badge. Instead, he is seen wearing the "Surface Warfare" Badge. Magnum is not seen wearing the S.E.A.L. Badge until "Memories Are Forever" (season 2).
5. FLUB FOR PART 2: After Magnum and the rest of the "Team" load up onto the chopper, Phillipe is seen at the LZ firing his M-16 Rifle. As he is firing you can see the Hollywood "Blank Adapter" just inside the "flash supressor." If you look closely you will see a small circular object (not to be confused with the actual barrel of the rifle). Blank Adapters are used when firing blanks from a rifle like the M-16, because without them you would not be able to fire multiple/continuous shots without re-cocking the rifle after each blank fired. The "Hollywood Blank Adapter" is a small adapter that fits inside of the flash suppressor so that it is hidden from sight to provide realism. Other blank adapters are larger and bulkier and fit on the outside of the flash suppressor. Their purpose is not aesthetic, but functionality. They work in the same way as the Hollywood Blank Adapters, but they are clearly visible.
There has been some debate as to which hand the "Team Ring" should be worn. It has been mentioned that the "Team Ring" is supposed to be worn on the right hand. I don't know if this is correct or not, but in the pilot-flash back scenes most of the team members are wearing the ring on the left hand. Those include Rick, Phillipe, the RTO and the guy firing the flare. At the end of the episode, Magnum removes Phillipe's ring from his left hand.
| Back to top |
J.J. Walters Site Admin
Joined: 02 Jan 2007 Posts: 3470 Location: Suburbia, USA
| Back to top |
golfmobile Chopper Pilot Wannabe
Joined: 06 Apr 2007 Posts: 1131 Location: Atlanta area
Posted: Wed Oct 31, 2007 12:47 am Post subject: |
James,
For what's worth -- and I admit I may have lost the thread here about the wearing of the team ring -- but I thought the guys always wore it on their right hands, leaving the left hand/fingers available for a wedding ring, should that ever come into play.
I was watching "The Taking of Dick McWilliams" tonight and TM was shown wearing the team ring in several close-ups, and it was on his right hand.
If that helps . . . .
_________________ "Portside, buddy."
| Back to top |
Posted: Wed Oct 31, 2007 12:54 pm Post subject: |
golf,
That's true. They usually wear it on their right hand, but there have been many times where they wear it on their left hand, as well ("China Doll", "No Need to Know", "Tran Quoc Jones" and others). So far, I havn't found any specific mention that it MUST be worn on the right hand. Maybe it will pop up in Season Seven or Eight.
_________________ Higgins: It's not a scratch! It's a bloody gouge!
| Back to top |
Carol the Dabbler Fleet Admiral
Joined: 20 Mar 2008 Posts: 280 Location: Indiana, USA
Posted: Wed Apr 02, 2008 6:56 pm Post subject: |
| Minor quibble with the Plot Outline: I believe that Magnum does say he's picking up his buddy at "the airport," but as we see soon after, he's not talking about Honolulu International. He drives through the security gate into either Hickam AFB or the Navy's adjoining facility (which "Ski" refers to as "Pearl"), then takes interior driveways into the other facility. Sorry I'm not certain which way it went -- but in either case, it would be safe to say something along the lines of "he goes to pick up a buddy who's due in on a military flight."
| Back to top |
Posted: Tue Apr 22, 2008 4:05 am Post subject: |
| IslandHopper wrote: | | A flub I noticed during this episode was when Magnum and Ensign Healy were on the dock talking about Lt. Cook, Ens. Healy referred to a Japanese Zero. In referring to the Zero, he said "oh yeah, a 30 year old Japanese zero." Healy later explains that the Zero was shot down during the attack on Pearl Harbor. If that is the case, then the zero was more like 40 years old (39 to be precise) as this episode was aired in December 1980. |
It seems to me that there are two categories of flubs -- with continuity errors being the classic type (for example, Magnum's shirt is different in long shots versus closeups). The "thirty-year-old Zero" is the other type of flub, where a character says or does something that doesn't quite jibe with reality -- but we could say that the character simply made a human error, the way we all do from time to time. So maybe these aren't exactly flubs.
Another example of this second type would be Magnum referring to Mai Ling's Cousin Ho as "Uncle Ho" (in "China Doll").
| Back to top |
SelleckLover RENLEDUN, Protectrix of the Realm
Joined: 10 Feb 2007 Posts: 1017 Location: Sunny Southern California
| Back to top |
| Back to top |
Posted: Tue Apr 22, 2008 4:10 pm Post subject: |
| IslandHopper wrote: | | Magnum does indicate that he’s picking up a buddy from a military flight. He says something like he is picking up a buddy coming in on a “MACs” flight. MAC is an acronym for “Military Airlift Command.” |
Thanks, IH -- I couldn't remember that acronym. I see that James has already changed the Plot Outline -- thanks, James!
| Back to top |
